Squealing belt! Vette Setup
Old Jun 19, 2011 | 02:57 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Got a LS motor in the Formula with a 1998 Vette setup. Belt is new though. It squeals like mad at all rpm levels until warm, and then just over 1500 rpms. (Not much differant) I assumed maybe a bad idler, but nope. I regreased them with no issues. Its coming from PS area. I just so happened to drip some fluid on the ps pulley wham, squeal was gone for about 20 seconds then came back. I sprayed some wd40 on it and it went away for a little bit. any thoughts? Belt is brand new Dayco. It appears some LS motors have this issue from multiple threads on another site. All suggest the Gatorback. Ideas?
Old Jun 20, 2011 | 05:36 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Squealing belt! Vette Setup
Old belt, bad bearing in an accy, maybe alt, loose bolt rubbing a pulley etc
Old Jun 27, 2011 | 08:49 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Ended up being a bad tentioner itself, not the pulley. Installed a new Katech unit and it all went away. Nice looking tentioner too!
Old Jul 6, 2011 | 06:47 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Ehh the noise came back. Its fixed for good now. Careless me didnt have the crank pulley on enough. A smidge more and now everything is quiet lol. I noticed wear on the edge of the belt.
Old Jul 8, 2011 | 08:16 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Take a bar of ivory soap and while the engine is running CAREULLY rub the bar onto the belt underneath and the sides so the belt eats the soap up a bit. That should last a while but if not use black silicone and prepare to get a little messy but basically do the same thing. Coat the belt with a light film of silicone and this typically cures it for good.
Its not the perfect solution but sometimes on some cars the belts just squeal no matter what you replace so this works as a last resort
Galaxie500XL
Feb 1, 2020 04:53 AM
codeysabatini
Nov 10, 2015 04:07 PM
BDR
Nov 7, 2015 03:05 PM
R13_Braz
Sep 18, 2015 05:00 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
