T56 makes weird noise on decel
Old Jul 20, 2011 | 11:28 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Hey guys Im still breaking in my ls7 clutch and fine adjusting my tick mc.Now everything seems to drive good and shifts easy.But I noticed that in first gear if Im going slow enough or under 3000rpm and push the clutch pedal in,I hear some type of rattle and I can slightly feel it through my shifter aswell.As if the clutch itself isnt fully disengaged.Im wonder if I dont have enough travel on the clutch pedal and need to adjust the master a lil bit more.I dont want to over do it as the instructions say for the tick mc.At higher rpms in first gear does not make this noise or feel.Wondering if I should be worried about my clutch or if its a trans issue.Any ideas?
Old Jul 25, 2011 | 10:07 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: T56 makes weird noise on decel
Perfectly normal with the LS7 clutch. Its a reeeeal close tolerance and it freaked a lot of us out when we first started using them as it takes 5k miles or so to bed them in. It will go away not to worry
Old Jul 26, 2011 | 01:05 AM
Engine: 2005 LQ4
Axle/Gears: 3:54
thats good to hear.thought i installed the clutch wrong or something wasnt torqued down good enough and came loose or my m/c needs more adjusting.car drives great though,nice pedal,good bite of clutch.
theshackle
Sep 17, 2020 08:26 AM
sreZ28
Aug 14, 2015 07:48 PM
BlackBoulder
Aug 11, 2015 11:15 PM
hokis
Aug 9, 2015 03:57 PM
BrianI
Aug 9, 2015 11:52 AM
