Moving battery to driver side.
Old Aug 11, 2011 | 09:40 PM
Cam91z's Avatar
Car: 91 Z28
Engine: 305TPI
Transmission: 5 speed
I have a dumb question. I wanna move my battery to the driver side. But this bracket is in the way. Will it affect anything if i take it out?
Old Aug 11, 2011 | 09:58 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Re: Moving battery to driver side.
I actually had my battery on the driver side. No problems. Just remove.
Old Aug 13, 2011 | 09:55 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I have had a couple third gens without that bracket in place and I never had any problems.
Old Aug 13, 2011 | 10:43 PM
Guest
Guest
Posts: n/a
Move the battery to the right rear corner of the car. Left front is already the heaviest corner. Moving the battery back is equal to a 10-inch engine setback.
Old Aug 13, 2011 | 10:59 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
I moved mine over there, no problems after removing that brace.
Old Aug 15, 2011 | 10:50 PM
Cam91z's Avatar
Car: 91 Z28
Engine: 305TPI
Can't really move it back there. There are two 12 w6v2s back there... I Have another question, i made up an air intake. Im using a rubber 90, with the weight of it all, twists it down some. Wondering if most just let it hang and not worry about it?. Anyone had any problems just letting it hang?
Old Aug 15, 2011 | 10:53 PM
Cam91z's Avatar
Car: 91 Z28
Engine: 305TPI
Air intake
double post
Old Aug 16, 2011 | 09:23 AM
Engine: 450HP 355
Transmission: TH350
You should brace it, not the kind of thing you want to fall off.
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
Cameeeero
Aug 20, 2015 03:06 AM
AkDrifted
Aug 17, 2015 07:45 PM
Mister_Johnny99
Aug 14, 2015 12:59 PM
