LS Swap measurement
Old Oct 13, 2011 | 12:48 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
LS Swap measurement
Can some people that have done LS swaps post a measurement for me? I am wondering what you are getting from the number 8 intake runner, top, to the bottom edge of the cowl. I have no rear or transmission crossmember in the car right now as I am working on a project in the rear, but I need a ballpark so I know approximately what the engine angle should be.
Old Oct 14, 2011 | 11:39 AM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Re: LS Swap measurement
im pretty sure there will be a slight variance in measurements from diff. members due to manufacturing defects/imperfections in the aftermarket mounts along with different ones being used like Spohn vs SBC plates.
Old Oct 14, 2011 | 01:28 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I can get a measurement of mine but im using welded solid mounts to the K member moved back a couple inches so I didnt have to notch the K Member at all. Up to you if that will work for you or not
Old Oct 14, 2011 | 05:41 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I am not too concerned about slight differences. I need a ballpark as the engine mounts are just resting on the crossmember and I dont have a trans crossmember so I need to know how far to jack the trans up so I can start figureing stuff out. I am doing WAAAY more than an LS swap, but I have no initial reference because my car had no engine or trans really. I can figure out my driveline angles, but when I am measuring stuff for the rear and the front of the car I can use this estimate to check stuff. I may be moving the engine slightly forward or rearward too and if I have something to reference I can be close to what I need
If you are at a height close to the Spohn or other mounts that could be good enough, thanks
GTAman
Mar 15, 2019 11:40 AM
deracer
Apr 11, 2016 12:04 AM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
theshackle
Aug 22, 2015 06:52 PM
