No Power Steering?
Old Nov 13, 2011 | 12:40 PM
NotTyler's Avatar
No Power Steering?
My car runs and drives finally, but I have no power steering? I used the ps pump that came with my ls1, and the pressure line from the ls1, the other hose came off the iroc.
It doesn't whine, leak, or really do anything at all. We have bled all the air out of the lines so that shouldn't be the problem. Any suggestions would be great.
Thanks,
Tyler
Old Nov 13, 2011 | 01:59 PM
Pocket's Avatar
Car: 91 Trans Am
Re: No Power Steering?
How long did you run it? It takes a while to fully prime the system once its been opened
Fire it up and turn it full lock left to right several times. Each time should be easier than the last
Old Nov 16, 2011 | 04:34 PM
NotTyler's Avatar
I've probably ran it for an hour minimum, and done the whole lock to lock thing a lot. It works half the time now, I drove it down the road for the first time and it works if I turn slow, but if i turn one way then turn it the other way kinda fast there is none lol. This thing is confusing.
Old Nov 16, 2011 | 04:37 PM
Pocket's Avatar
Car: 91 Trans Am
Check the fluid level
Squeaky8791
Feb 5, 2020 08:29 PM
Vintageracer
Jan 10, 2020 05:33 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
