ls1 or 5.3
Old Nov 14, 2011 | 10:26 PM
Scott92Camaro's Avatar
Car: 1992 Chevy Camaro
Engine: 305 tbi
Axle/Gears: 273
ls1 or 5.3
im wanting to put an ls1 or a 5.3 engine in my 92 camaro rs but im tryin to learn the hp and tq rating and all the other goodies but one main question i have is what is the difference between the ls1 and the 5.3 besides the iron/aluminum block!?
Old Nov 15, 2011 | 09:16 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: ls1 or 5.3
I'm sure this will get moved (LSx forum section would be better fitting), but the LS1 was 5.7L, where as the 5.3L is, well, 5.3. They are pretty close in power (about 30-50 hp IIRC depending on the year). 5.3 will be usually cheaper, but it will require you get a few of the LS1 fbody parts (intake, accessories, oil pan, exhaust manifolds) to fit in a 3rd gen, so the the price difference will shorten up a bit.
boosted guys like the iron blocks because they are a bit beefier and cheap. also, there is enough meat to the cylinders to bore out the 5.3 to an "iron LS1", but the cost would probably be better spent stepping up to a 6.0
Old Nov 15, 2011 | 08:23 PM
Engine: 305 tbi
Axle/Gears: 273
Re: ls1 or 5.3
yea i was doin a lil research and saw that the entakes were different (runner wise) and i was wondering all what else was different between the 2 but im pretty sure i wanna go the 5.3 route for my car and a cam swap maybe some head work and a full exhaust swap and keep the 700r4 and then do my rear end swap and if i can get around 450hp i will be on top of the world happy with my car and i know that should be a prob with the 5.3 lol
Old Nov 15, 2011 | 08:47 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: ls1 or 5.3
LQ9 FTW
Old Nov 15, 2011 | 09:00 PM
Engine: 305 tbi
Axle/Gears: 273
Re: ls1 or 5.3
and another question i have is do the ls1 and the 5.3 use the same conversion motor mounts and computer an wiring harness!?
Old Nov 15, 2011 | 09:10 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Re: ls1 or 5.3
there are plenty of swap stickies in the top of the lsx swap page, and yes ALOT of the ls parts are interchangeable and work in the same form and place.
Old Nov 15, 2011 | 09:15 PM
Engine: 305 tbi
Axle/Gears: 273
Re: ls1 or 5.3
ok i know this might be a really really dumb question lol but is "lsx" considered ls1 as well!?
Old Nov 15, 2011 | 09:22 PM
Awesome-X's Avatar
Car: 87 Camaro
Re: ls1 or 5.3
The X is only a placeholder for the number. Ls1 Ls2 Ls3 etc.
Old Nov 15, 2011 | 09:23 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Re: ls1 or 5.3
well you have the lsx block that is with the ls family but a someone that has lsx on the side of a random car would more than likely stand for the whole ls family imo.
Old Nov 15, 2011 | 09:32 PM
Engine: 305 tbi
Axle/Gears: 273
Re: ls1 or 5.3
ahh ok thanks guys i appreciate it ALOT and so the mounts and all the wiring are the same even the computer!?
Old Nov 15, 2011 | 11:23 PM
Pocket's Avatar
Car: 91 Trans Am
Re: ls1 or 5.3
Mounts yes
PCM/harness no. Too many options and variables for a one size fits all answer
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
