2010 camaro engine cover??? will it work
i didnt know where to ask this question so i figure i would start here//
ive seen many 5.3 swaps with people using the aftermarket fuel rails
i just bought a z06 ls6 intake for my 5.3 truck sway for my 88, so can i use the stock rails? do i need aftermarket regulator?
if i can stick with stock ls6 stuff can i use a 2010 camaro engine cover,(back and silver) on the ls6 intake and hide all the stock stuff, and to add the look of factory wownesss!
Re: 2010 camaro engine cover??? will it work
Read the sticky for your fuel system questions. They're answered in great detail
The cover most likely will fit well enough to leave. Not sure how many people will be wowed by a huge chunk of plastic hiding the major accomplishment of a LSx swap. Why not stick it on a 2.8 and just put LSx badges on the car. Looks the same in the end
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
No go on the cover, you'd need to splice two together to make it not terrible. There is no cowl on the Thirdgen.
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
i actually like that look for what im doing. then i can always take it off if i want to. i was trying to decide which to go with this or the corvette cover
what do you mean splice the two?
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
It does fit.
This was before my l92 head swap. No cutting at all
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
