Seafomed the ls1 bird
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Now i know this motor was well used and abused before I got it and its was high mileage and poorly maintained.It ran ok from what I thought..was slightly sluggish below 1500rpm and was going from rich to lean all the time on the driver side bank.This motor is due for a rebuild with number 7 gettin piston slap and loss of compression and leaks oil.I have switched to royal purple oil,trans and diff fluids and notice a good increase overall in performance.Tried some injector cleaner aswell as engine oil treatments and things ran smoother but then slowly went back to sluggish behaviour.
So I said screw it and lets see what the hype is about with seafoam during my next oil change.I expected the motor to be very badly clogged up and boy was it ever!Use a full bottle and it hasnt fully cleaned out yet lol but wow what a difference.It holds a steady stoich ratio,gained bottom end torque back and gas mileage has went up.
Word of advice to anyone who wants to do this and you know for sure the motor is very badly full of gunk.Do this near a bigggg open field..maybe even at night lol.I had fire trucks and cops searching for a burning house from it lol and shut the car off and ducked inside my house through the fog haha.
And heres a short clip of the mayhem:
http://youtu.be/k_JO9eazJfc
Engine: Cammed 6.0L LSX
Re: Seafomed the ls1 bird
I ran that thru the tpi motor and about 1,000 miles later the diaphragm under the plenum crapped out and I was blowing blue smoke everywhere. Coincidence? Maybe.
Engine: 2005 LQ4
Axle/Gears: 3:54
Ive read good and bad things about it.I know its pretty harsh stuff and not to leave it in for too long since it eats away at rubber,oil,carbon etc.Heard some guys having metal shavings in the pan afterwards.I didnt put the stuff in the gas tank or the oil.Just the vacuum brake line.
Car: 1991 camaro RS convertible
Engine: EFI 383 150shot nitrous.
Axle/Gears: 2:73...
i seafoamed a 84 bronco and 2 weeks later spun a barring it might have been cuz it was a ford hope nothing bad happens let us know how it goes
Engine: 2005 LQ4
Axle/Gears: 3:54
Yea im keeping a close eye on how things are going.this motor is already in need of tlc so it wont bother me if it finally dies lol.more motivation to rebuild and upgrade and not look back at stock.
Axle/Gears: 2:73...
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
back when carb's were still around all you had to do was run a little tranny fluid through the top....it normally did a good job of cleaning everything out......
Axle/Gears: 2:73...
<---me lol Senior Member
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
I seafoamed my dads 140k colorado and 2 weeks later it blew a head gasket.. Hope that was just a flewk also...
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Sea foam works i don't see it being a conspiracy theory just a big *** coincidence the motor was junk.
Engine: 2005 LQ4
Axle/Gears: 3:54
Well so far a week later Im having no issues.Checked my oil and all is good,car runs like a top and my gas mileage has improved.
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Engine: 2005 LQ4
Axle/Gears: 3:54
Just the fuel and vacuum line.The reason I didnt do it through the front tb vac line is because of wanting to really clean out the rear cylinders compared to the front.And I think the results were evident this way using the brake booster line.
To me for the $20 i spent it was worth trying.After the motor is rebuilt,I wouldnt try this stuff unless I had alot of miles on the rebuild.It seems like its pretty harsh stuff and should not be left in longer than instructed or you could get issues as others have stated.
Car: 1992 Camaro RS Z03 T-Top
Engine: L98 with TBI
Axle/Gears: 2.73...
When I first got my car and it had a 305 I ran it through the gas tank and pour half directly into my tb. Guess I should've chosen a better time since my exhaust was off at the time... but yeah got the fire department called on me lmao. No issues with it at all and it ran so much better, much more throttle response.
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
Your gonna want to change out the oil soon. Do that WITHIN 300mi. It'll be super gunked up and black. Changing the oil after a sea foam treatment is VERY IMPORTANT.
Car: 1991 Camaro Z28
Engine: 5.7L
Is this only if you add it to the oil directly? Was under the impression this wasn't required if the seafoam was added to the intake and fuel.
Car: 1992 Camaro RS
Nope. If you do a seafoam treatment you change the oil soon afterwards.
Car: 1992 Camaro RS
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
hmmm just seafoamed this weekend 1/3 via charcoal canister vac line and 1/3 into the half tank of gas. Missed the part about changing the oil at 300 mi. Have to check the oil getting black. Funny tho no smoke at all on that 1/3 into the TPI.
From the seafoam site:
The most frequently asked question about using Sea Foam® is as follows: “After using Sea Foam® in my oil, fuel, or through the vacuum line (to clean carbon from the combustion chamber) do I need to change my oil?” The short answer is: No you don’t have to change your oil after using Sea Foam® in any application.
SKEL why do you say within 300 mi?
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
this is no different than using gm top engine cleaner. maybe slightly milder. no reson to change your oil unless you allowed it to soak past the rings overnight and feel your oil in contaminated with it. I personally dont feel anything above ATF is needed when cleaning the oiling system. (5quart system.. 4quarts oil 1 quart ATF) if its that bad where a few cycles with the atf didnt clean you surely have underlying issues
the only reason I would see a failure is...
A... you sucked too much in too fast and hydro-locked the engine and damaged the bearings or bent a rod.
B... you were thinking (good old mechanic in a can!) and youre issue would be fixed by a half hacked approach when the real issue was never addressed or even properly diagnosed... then the real issue just gets worse as it would anyway regardless of the half attempt at a repair
Engine: 2005 LQ4
Axle/Gears: 3:54
I was told the same thing by many guys who have used seafoam.You dont have to change the oil...but after doing a topend clean up..why not put in fresh clean oil aswell.Not going to hurt in doing so..just better reassurance that you know you got everything out and fresh oil now circulating in the motor after is been cleaned and beaten on.
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
used seafoam on my old truck (88 chevy 4x4) it hated drinkin it but man did it make a difference. i also had the fog of death lol. me and my buddy who was doin the same to his camaro administered it under the cover of darkness outside our dorm when we were stationed in missouri. it didnt help that it was humid and the doom cloud just stayed low to the ground and headed straight for the security forces building haha.
Axle/Gears: 2.73...
Axle/Gears: 2.73...
Ah just asking because I couldn't think of another air force base in MO.
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Ive used seafoam a 6years ago with no issues. Put a full can in the gas tank, half in the oil and the other half in the vacuum system and used a full can of the spray into the TB/Intake area. Ran the car for 100miles and changed the oil right after. Oil came out DARK BLACK and very diluted. Car has been drag racing and taking long trips ever since. No issues
