98 ls1 harness pcm repin to fit 99 ls1 pcm
Old Dec 6, 2011 | 10:54 AM
gregX10A's Avatar
Car: 1989 pontiac firebird formula 350
Engine: 5.7l tpi
Axle/Gears: gm 10 bolt/3.73 gears
Hey guys I'm doing an ls1 swap into my 89 firebird and I have a 98 camaro donor car. The thing is I don't want to use the 98 pcm and would rather use a 99 or newer pcm. I heard you can repin the 98 harness to work with the 99 pcm, is this true? And if so is there anything else that needs to be done to the harness or engine?
Old Dec 6, 2011 | 11:49 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: 98 ls1 harness pcm repin to fit 99 ls1 pcm
welcome to tgo. we have a sub forum on the engine swap forum for ltx and lsx swaps, youd have a better chance getting the right answer there.
Old Dec 6, 2011 | 12:16 PM
gregX10A's Avatar
Engine: 5.7l tpi
Thanks, ill repost there
Ikes 91Z
Dec 9, 2015 03:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Keith5
Aug 27, 2015 04:37 PM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
