4th Gen Gauge Cluster Wiring
Old Jan 8, 2012 | 08:24 PM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Next post...
Old Jan 8, 2012 | 11:40 PM
Rich92 RS's Avatar
Transmission: T56's
Re: 4th Gen Gauge Cluster Wiring
Alright so these are the pinouts to my 98 Gauge cluster, and what I think Im suppose to splice the corresponding wire to. Does this look right at all?
Legend:
Question marks: I dont know.
"3rd Gen": Splice into the stock thirdgen cluster connectors.
"N/A": Dont need/Not using.
Attached Thumbnails 4th Gen Gauge Cluster Wiring-wiring-98-gauge-cluster.jpg
Old Feb 21, 2013 | 10:00 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Pinouts from TPITERROR
A3 PNK 39 Ignition Power...to 3rd gen Clear Connenctor #2 or #6 Pnk w/Black
A5 TAN/WHT...to 3rd gen Clear Connenctor #7 Brake Reservoir Sensor
A8 BRN/WHT 419 SES light to
A10 ORN 640 Constant Battery 12v
A12LT BLU 14 Left Turn Signal Lamps...to 3rd Gen Black Connector #8
A13 PPL/WHT 237 Instrument Panel Lamp Control ??????
A17 LT GRN 11 Headlamp High Beam... to 3rd Gen Black Connector #10
B1 BRN 9 Park Lamp Supply Voltage...Power w/parking lights
B3 GRY 728 Security Indicator Control (Not used)
B5 PPL/WHT 1035 Starter Coil Supply Voltage...Hot in start, yellow wire from Ign, Switch
B6 GRY 1036 IPC Class 2 Serial Data...from LS1 PCM
B7 ORN/BLK737 Trunk Lamp Control (Not used)
B8 DK GRN/WHT 817 VSS Signal..from LS1 PCM
B9 GRY 8 Instrument Panel Lamp Supply Voltage ??? Lamps form Dimmer
B10 DK BLU 15 Right Turn Signal Lamps...to 3rd gen Clear Connenctor #12
B11 BLK 650 Ground....to 3rd gen Clear Connenctor #9 or or Black Connector #10
B14 TAN 31 Oil Pressure Indicator Control...from LS1 oil sending unit
B15 BLK 650 Ground... to 3rd gen Clear Connenctor #9 or Black Connector #10
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Casey Meyers
Mar 2, 2016 10:46 AM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
