94 LT1 swap from injection to carb
Old Feb 19, 2013 | 02:16 PM
BLswhitehawkta's Avatar
Hi my names Brandon I'm doin a motor swap for a guy I wrk with he has a mid 70's stingray. We want to put in an LT1. Just bought one for cheap already disassembled already I want to kno wat I have to do to make it carbureted we not worried bout smog or anything like that. It's set up for injected right now but we don't want to put all the wiring in the sting ray cuz it's all numbers matching car. We wana modify as little as possible to the car itself it already has a 350 carb. Any help would be great seen it done on ls1 blocks
Old Feb 19, 2013 | 04:50 PM
toomany's Avatar
Re: 94 LT1 swap from injection to carb
Basically you need a carb manifold. GMPP makes one. You can then drop a distributor in (after you remove the stock drive plug). That is all that is really needed for it to run with a carb. If you wanted to keep the opti, then there is more work needed...but it sounds like you don't want to do that. What accessory drive are you using? I'm pretty sure standard SBC stuff doesn't bolt up the LT1 (even though I own several SBC's and a few LT1's...I've never tried). Corvette accessories are on the drivers side, B/F-body are on the passenger side (very similar but not the same).
Intake: http://www.summitracing.com/parts/NAL-24502592/
Old Feb 19, 2013 | 07:33 PM
Wat do u mean accessories as in ac and heater I don't think it has any functional. And ways the opti. Not familure with LT1 blocks
Old Feb 20, 2013 | 12:35 AM
Ur referring to the opti as a distributor right
Old Feb 20, 2013 | 08:33 PM
toomany's Avatar
Yes, opti=optispark=distributor. It is on the front of the motor, driven by a pin on the camshaft.
As far as accessories, alternator, power steering pump, ac compressor. The water pump is driven with a shaft out the front of the optispark.
Old Feb 20, 2013 | 10:56 PM
Would I be able to use a reg hei an a reg water pump how would I make that wrk cuz the opti needs a comp to wrk right. How doin go about makin it wrk
Old Feb 20, 2013 | 11:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I think you'll get more useful information in the LTX and LSX subforum.
Old Feb 21, 2013 | 05:20 AM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
You have to use the LT1 water pump along with the accessories unless you can fab something else up somehow. Opti would only be needed if you were using the PCM. Honestly, I would think you would be better off with the fuel injection. The car won't be numbers matching anymore if you swap the engine.
Old Feb 21, 2013 | 10:40 PM
We're no tearing the number matching block apart for that reason so we could always change motor bak. And we don't wana add all the electrical **** and computer. Wana keep it old school. But new school
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
