For you LT1 swappers, cheap insurance for the oil pump drive
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
http://pro-jectioneng.com/ops.html
anyone doing an LT1 build, NEEDS this little, inexpensive, easy to install piece that can save your engine in the event of a broken oil pump drive. The LT1 uses a composite plastic oil pump drive head that bolts to the block. They have been known to crack and break, causing catastrophic oiling failure. Using this brace, will save the pump from failing if it breaks.
I bought one back when i was putting my LT1 together, its very cheap to buy (i think its $14 or $15)
just thought i would pass this along
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
mcquigg
Aug 13, 2015 02:26 PM
92camaroJoe
Aug 13, 2015 06:07 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
