BRP / headman 1 3/4" mid length how much power they good for?
Old Jan 16, 2012 | 04:04 PM
91_B4C_RS's Avatar
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
370 lsx carbed
Ported victor jr l92 /ls3 intake
Ported/milled ls3 heads
235*/251* .621"/.631"110lsa. Eps camis should peak at 7200rpm
Flattop pistons 11.25:1 compression
850 proform carb.
What are your guys opinion. Should make around 600fwhp.
Exhaust is going to be 3" duals. With turndorns right behind driver. Short exhaust.
Will these be choking the engine?
Can't find a set of used hawks headers.
http://www.brphotrods.com/mm5/mercha...gory_Code=CNV1
Old Jan 16, 2012 | 05:41 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: BRP / headman 1 3/4" mid length how much power they good for?
buy the 1 7/8" headers at least in long tubes, those shorties will choke the engine.
Old Jan 16, 2012 | 05:55 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
With a better collector I dont think they would hurt too bad with dual 3" being so short. Lsx can get away with larger headers tho. Think you'd need abit more cam than that to hit 7200 rpm peak but still should make power either way.
Old Jan 16, 2012 | 07:23 PM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
sounds noisy to me....i love my brp lsx swap mids. i'm not as cammed as your combo, but i don't think its holding much back and i neck down to 2.5" pipe in my y. great quality on their product. i've always been pleased with hedmans headers.
BRoss99
Aug 10, 2025 05:08 PM
TheJoeY88
Dec 31, 2016 07:30 PM
InfinityShade
Aug 22, 2015 08:00 PM
mdtoren
Aug 16, 2015 05:45 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
