cheap 350 vortec
Car: 1984 camaro z28
Transmission: 5 sp
cheap 350 vortec
ok, a guy in my area is selling a 5.7L vortec 350 with 68,000 out of his wrecked 2003 1500 truck for 200 bucks..thats pretttty cheap..question is they must have put a different motor in the truck because they didnt make the 5.7L in 03 for trucks anyway, at least thats what i c on wikipedia..whats the best way to tell what this motor is? casting #s, external visuals? i would do the research myself but i need to go to work and may not have time to do it before i check the motor out..it might be gone before i can do any research. appreciate any insight. i will have someone to help me diagnose the state of the motor when i go hopefully..since it was in a wrecked vehicle etc. are computer/wiring harnesses expensive for an assumingly late model vortec 350 also?
Car: 87 IROC
Engine: LB9
Axle/Gears: 3.70 9 bolt
Re: cheap 350 vortec
Check the VIN. You are right that the 2003 1500 didn't have a 5.7L Vortec. It is likely a 5.3L LM7. Check the intake cover and it probably says "Vortec 5300."
2003 Silverado:
VIN T - LM7 (iron block/aluminum heads)
VIN Z - Flex Fuel L59
If it's really a stock 2003 1500, then it has a 5.3L will is still plenty of motor for you.
2003 Silverado:
Transmission: 4L80E/4L80E
External visuals are pretty simple. Stamped valve covers, distributor - earlier Gen I. Coil-on-covers, LS-type.
If it is a 5.3, then try to get the harness & PCM with it (and transmission if it's 2WD). $200 isn't too surprising - you can get a good used 5.3 with warranty from the JY's for less than $400.
Fast355
Dec 2, 2016 06:33 PM
Eric-86sc
Aug 24, 2015 09:01 PM
