Radiator hose collapsed during break-in?
Old Feb 9, 2012 | 02:47 PM
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
Transmission: 4L60E 3,200 Edge stall
Axle/Gears: 9 bolt w/3.90
I have a GTA that just got a H/C, LS6intake LS1. During break in the lower radiator hose collapsed, choking off flow to the water pump and causing the hose to blow off at the radiator neck (lower).
I think the hose was thru Hawk's. It is smaller in diameter in the main part than where it connects to the water pump and radiator, resulting in a stepped appearance.
Has anyone seen this before?
Old Feb 9, 2012 | 02:52 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Re: Radiator hose collapsed during break-in?
i havent had the problem nor seen anyone post about it. I ran a cherokee hose, i believe Five7 said something somewhere about the part# he used, trim and fit, works like a charm, no rubbing.
Old Feb 9, 2012 | 03:05 PM
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
thanks for the fast response and the help.
Old Feb 13, 2012 | 06:01 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
if you need a new lower hose i got a part number for the hose that you need... not that stupidly overpriced one.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
