MAP sensor
Old Feb 19, 2012 | 12:22 PM
croozer's Avatar
MAP sensor
Will the MAP sensor from a '02 tahoe work for a swap if you dremel the wings off of it?
One Thread I read said that GM Standardized the MAP signals. So I'm assuming that it would would work. I just wanted to make sure before I started cutting.
Thanks!
Croozer
Old Feb 19, 2012 | 12:57 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: MAP sensor
Have you pushed it in the hole to see if it will fit? Some have larger diameter seals than others.
Old Feb 19, 2012 | 05:34 PM
croozer's Avatar
Re: MAP sensor
the hole looks like it would fit, but I can't get the sensor to the hole, because of the wings on the sensor.
bad picture, sorry. but I think it kind of shows my issue. I don't want to cut those tabs or wings off of the sensor if it won't work. anyone try this before?
Croozer
Attached Thumbnails MAP sensor-02-tahoe-map-ls1
Old Feb 19, 2012 | 09:50 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: MAP sensor
Gigady
Old Feb 20, 2012 | 07:18 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: MAP sensor
as long as it is a regular 1-bar off the gas vehicles and not the 3.3 off the diesels, it will work without pcm issue, you just need to cut off the extra set of fingers that get in the way of the intake.
Old Feb 20, 2012 | 08:02 PM
croozer's Avatar
Re: MAP sensor
Well, I trimmed the edges of it, and it fit. I included a picture. So if a person ever needs to, they can use a modified Truck MAP sensor. Thanks for all of the help everyone!
Croozer
Attached Thumbnails MAP sensor-map-sensor-modded-test
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
efiguy
Sep 27, 2015 01:30 PM
