Injector size calculations
Old Jun 12, 2018 | 03:39 PM
  #51
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Injector size calculations
Originally Posted by 5Camaros
What would the original pressure rating for the fuel injectors on a stock 1991 Z28 5.0L
I have to replace the injectors - being told they should be around 44psi
Correct. 40-44 psi with the key on and the engine not running is roughly where you want to be. If you're using injectors rated the same as the originals (19# @43.5psi), not changing the regulator and the pump is good then you'll see that number.
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
69 Six Pack
Oct 5, 2015 07:51 PM
bamaboy0323
Sep 3, 2015 06:07 AM
knight72
Aug 10, 2015 09:32 PM
