need some info that i cant seem to find
Old Mar 1, 2012 | 07:47 PM
iloverocs's Avatar
Car: 1988 iroc-z
Engine: 5.7 tuned port
im doing a 5.3 swap into my buddies car and i have everything pretty much ready to drop but the oil pan i see allot of people are saying ls1 f-body pan but i have a ls2 Cadillac pan sump assy and i was wondering if that would work for him i don't want to go through the trouble of putting it on and dropping it in and have it not work any info on this would be greatly appreciated thanks
Old Mar 6, 2012 | 01:57 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: need some info that i cant seem to find
I think most everybody just uses what is known to work. Is it really that much of a hassle to lower the engine to check for clearance with the oil pan you have? Who knows, you may have found another solution and it only took about 1 hour of test fitting to find out.
Old Mar 6, 2012 | 03:17 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Based on pics just posted in another thread a couple days ago (i.e. read the forum!), the CTS-V pan that I believe you're referring to sits about 1.5-2" lower than the k-member. The last thing you want is for the oil pan to be the lowest thing under your car. That's just asking for trouble. The f-body pan is the only GM pan that fits in the car and doesn't extend below the k-member. Holley and Mast both have aftermarket pans out now that look like they'll work well though.
Old Mar 8, 2012 | 07:35 AM
iloverocs's Avatar
Car: 1988 iroc-z
yeah i did the test fit and im not comfortable enough to use that pan it does hang lower then the ls1 oil pan, now has anyone used a autozone ls1 pan?
Old Mar 8, 2012 | 08:21 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Autozone oil pan? Are you referring to the Pioneer pan part # 501085 ?
That appears to be a stamped steel pan and Im not even positive how they can sell that to fit an LS1 application. Unless their picture and description are incorrect, which I wouldnt put past them.
But given the price, Im guessing its just a stamped steel pan. The LS1 pan is intergral to the front and rear covers lining up. Between that and the way oil pick up sits, I wouldnt use it even if it did bolt up.
Just keep looking for a used LS1 pan and you'll find one. Or if you know someone that can weld aluminum for a decent price, get the pan you have already modified to fit.
J.
Cornholio7979
Sep 20, 2018 02:31 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
jer4251
Sep 1, 2015 09:04 AM
ambainb
Aug 29, 2015 12:43 AM
gta power
Aug 13, 2015 06:15 AM
