LS1 power steering whine
Old Mar 11, 2012 | 10:58 PM
IrocZ'85's Avatar
Car: '85 IrocZ
Fired up my LS1/4l60e swapped combo for the first time this year to drive it around. Immediately noticed that the power steering whines like a loud weed wacker lol.
I'm running the stock LS1 pump to the steering box and the lines are good and don't look kinked. It has fluid too and doesnt seem to be leaking. Is this normal, is the pump dying, or do the flow characteristics of the LS1 pump vary massively vs the original gen1 SBC pump?
If the latter is the case, and the LS1 pump is higher pressure, im sure some seals won't last too long....anyone else had this issue before? its obnoxious lol
Old Mar 11, 2012 | 11:31 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: LS1 power steering whine
......I posted a while back about my pump starting to whine.Everyone on here warned me to replace it.It didnt leak then....and then bam.Pump leaks non stop right out of the front seal.Sad thing is..you cant just patch these pumps up with seals..can only buy remanned pumps.Plus all the fluid it leaked out onto my belt and all over my 160amp lq9 alternator killed that aswell. Start shopping for a pump is my advice before it gets worse and dont try using thicker ps fluid to quiet the noise,it will only stress the pump more.Good luck
Old Mar 12, 2012 | 06:31 AM
IrocZ'85's Avatar
Car: '85 IrocZ
ok thanks, ill check and see if i can get another one. Then I'll replace it and see if the whine goes away. I'd still like to get pressure and flow data on this pump to see if its overkill on the stock system. But it seems like other people have run it with no problems....
EDIT: I will also properly burp the system as there may still be bubbles in there as well. Will report back after I check and double check everything.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
sailtexas186548
Aug 24, 2015 10:11 PM
zayne0
Aug 24, 2015 07:22 PM
