Lt1 ac wiring
Old Apr 15, 2012 | 08:39 AM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
Lt1 ac wiring
I have an lt1 swap with he corvette a/c setup. I need to know if there is a way to see if I have my setup wired properly. The setup doesn't have any pressure in the system.
Old Apr 15, 2012 | 10:22 AM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: Lt1 ac wiring
I stumbled along this. Maybe it will help
https://www.thirdgen.org/forums/ltx-...-c-wiring.html
Old Apr 25, 2013 | 09:41 AM
BCdawg57's Avatar
Re: Lt1 ac wiring
Little bit late but thanks that does help a bit. But i want to know is there a way to verify it works. Should i get voltage at the low pressure switch with the ac request on with no charge on the system?
Old Apr 25, 2013 | 11:09 AM
BCdawg57's Avatar
Re: Lt1 ac wiring
Well I answered my own question. I went out with an ohm meter and the blue wire on the low pressure switch has continuity with the compressor, and the green wire has continuity with the hvac controls. So as long as everything works properly i should have a working a/c system.
Now, how do i know how much freon to use? Do i go by 1991 specs, or those from a 95 corvette since that is the compressor i will be using?
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
