LT1 Swap questions
Old May 1, 2012 | 10:25 AM
Turk's Avatar
LT1 Swap questions
I saw the sticky on the 700r4 but the link was dead so i wanted to know what i need to do to ensure these 2 play nicely also if anyone out there could answer this you'd be awesome:
I want to get the following cam:
http://www.summitracing.com/parts/CCA-K07-468-8/
(0.584 int./0.579 exh.)
will the stock pistons clear the valve with this cam?
also getting the http://www.summitracing.com/parts/CCA-RP1418-16/ rocker arms
I am using 95 ported lt1 camaro/firebird heads with an lt4 intake port matched.
Thanks in advanced
Old May 2, 2012 | 07:38 AM
Z28 MeTaL HeAd's Avatar
Engine: Carb'd LT1 w/ a Cam :)
Axle/Gears: Moser 9" w/ 3.75 gears
Re: LT1 Swap questions
Thanks in advanced
Thats a terrible cam to put in a stock bottom LT1. WAY to much duration. You'll lose so much low-end its crazy. Yes, the stock pistons will clear that much lift. I've got a .592/.592 lift intake/exhaust custom grind LE cam on my stock bottom LT1 w/ 228/236 @0.50 and I even upped the compression using Victor Reinz 0.26" compressed head gaskets and mines fine on ported stock 95 Camaro '643' casting heads.
The roller rockers are the same ones im using, no issues to report, work great!
Are you sure youre using an LT4 intake? They dont bolt right up to stock LT1 heads IIRC.
Old May 2, 2012 | 08:00 AM
Turk's Avatar
I didn't check the casting numbers or anything but the guy i bought it from is a buddy who hasn't been known to lie to anyone about parts and is a serious LT head he has parts for days. When i get home ill check all the numbers and post em so you guys can have more information... any suggestions on a good cam i'll take into consideration as i havn't ordered the cam yet because i'm still researching and trying to learn what the best cam would be giving the circumstances.
Old May 2, 2012 | 10:02 AM
There is no 'best' cam as it all depends on if it matches your combo as a whole.
Your best bet would be to call up Advanced Inductions and talk to them about your combo and they will spec out the best cam you can think of for your LTx.
Lloyd Elliot is really good too. Very helpful and extremely knowledgeable. Give either of these guys a call and talk to them, they'll set you straight.
What are your goals? ET? Trap Speed? Street-ability? HP? TQ? Street? Track? Drag? Circuit? Gearing?
All this plays a factor in the type of cam you choose.
My stock-bottom LT1 is making damn near if not just over 400rwhp and will run 11's when I get back to the track, guaranteed, and im N/A 6-speed.
Old May 2, 2012 | 05:54 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
I emailed LE about porting a set of heads 6 months ago and haven't got a response yet. So his customer service sucks in my opinion. I will agree about that being waaayyy too much for a stock bottom end lt1.They tend to start spinning rods at 6700ish rpm, probably where you'd have to shift that cam.
There was a user on ls1tech that used that cam on a stock bottom end car, it was still making power when they hit the limit of the pcm, about 7200rpm.
Old May 2, 2012 | 05:59 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Originally Posted by blue85305
I emailed LE about porting a set of heads 6 months ago and haven't got a response yet. So his customer service sucks in my opinion. I will agree about that being waaayyy too much for a stock bottom end lt1.They tend to start spinning rods at 65-6700ish, probably where you'd have to shift that cam.
I've never had any issues with Lloyd. Just call him on the phone, he'll talk for hours.
As for that cam you posted? I hope to god that you have a built bottom end, or a 383/396 cause that cam is WAY too big for a stock bottom end LT1, no way it'll be happy reving has high as that cam would need to be rev'd.
IMHO I wouldn't consider going past 6700 on a factory stock never opened bottom end. You start regularly going past that and things may get dicey.
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
