4l60 to t56 wiring
Old May 2, 2012 | 08:47 AM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
4l60 to t56 wiring
I bought a harness off here specific to lt1 but it has 4 l60plugs. Im going to run the 6 speed.what do i need to do wiring wise?
Old Jun 25, 2012 | 10:17 PM
jaysfs's Avatar
Transmission: t56
Re: 4l60 to t56 wiring
Anyone went from a 4l60e to a t56? any insight or write up for it?
Old Jul 6, 2012 | 01:51 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
You'll have to get the plugs for the reverse lockout, and reverse lights, you'll need to wire up a power feed for the reverse lockout, the reverse lights go through the C100, your vss connector should be the same, and you'll want to program cags out in the pcm unless you want it to stay functioning and then you'll need to wire it.
Old Jul 22, 2012 | 08:52 PM
jaysfs's Avatar
Transmission: t56
i do haveq a pcm for a 6 speed already.
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
