quik questions - LT1 T56 VSS & speedometer
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Will the 95 lt1 pcm and t56 play well with the stock 92 camaro speedo? Or do I need a dakota box?
Transmission: 4L80E/4L80E
Need someone to verify this, but I believe the PCM speedometer output is 4000 ppm like the 3rd gen speedometer.
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Re: quik questions - LT1 T56 VSS & speedometer
Missed that part
All 3rd gen electric speedos that Ive seen require 4,000 PPM input. The best I can tell is LS1s use a 40 pulse per revolution input and change it to 4,000 PPM output to the speedo. The cruise output is 2,000PPM just like 3rd gen cruise
Regardless of older 3rd gens using a 2,000 or 4,000 PPM signal, the value can easily be changed when tuning the LS1 PCM to make what you have work
The dakota box is used to change LT1 T56 11/17 pulse per revolution signal to 2,000/4,000PPM 3rd gen signal when keeping the TPI
Well, now that I see pocket's post again, it may not be correct. Actually sounds like the LT1 output needs to be converted.
With all of the LT1 swaps that have been done, I would think the answer would be easier to find. I have no personal experience to relate, however.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Yes it will work directly without a converter.
You will have to splice the output from the pcm directly to the wire from the buffer box->instrument panel if its a TBI car.
Car: 1989 Trans Am GTA
Transmission: M28 T56
I'm not sure about the 94+ T56's, but the 93' T56 with its 11ppr ratio does kind of work with the thirdgen electric speedo.
Its about 6% high at all speeds. At an indicated 80mph I'm doing 75mph.
ambainb
Apr 25, 2016 09:21 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
