Lt1/4l60e vss buffer questions
Old May 14, 2012 | 01:40 PM
kenlamb3's Avatar
Car: 91 Z28 Convertible Camaro
Axle/Gears: Borg-warner 3:27 gears
Ok guys I need some help with this last part of my swap. I have a lt1/4l60e All hooked up and running but for some reason can't get it to shift out of first gear. Also my speedomoter doesn't move at all when I drive it. Also the car is not pulling any codes so I'm not sure were to trouble shoot, I've read that some had this issue and they had to bypass there vss buffer but my origanel motor was a 305tpi and if I understand correctly my car didn't come withi one (91 z28). With all the reading if been doing it seems that no one posted how they fix the problem, do I need to get a buffer box and hook it up to bypass? Thanks in advance.
Old May 14, 2012 | 03:25 PM
kenlamb3's Avatar
Re: Lt1/4l60e vss buffer questions
Could I be having this issue from using the vss from my 91camaro?
Should I be using the vss for a 4th gen camaro?
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
stickychinsac
Aug 31, 2015 06:06 AM
GTAman
Aug 27, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
marcusaw
Aug 10, 2015 08:13 AM
