5.3 wire harness swap ?
Old May 18, 2012 | 01:37 AM
89maroconvrs's Avatar
ok this might be a dumb question but im new to electronics. But im dropping in a 5.3 and i got the whole harness plus the computer and the car im putting it in is gutted. can i just use the harness as it is and just wire up my gauges, fuel pump and what not to the truck harness since im changing all that anyways and just figure my ignition out? any input would be apreciated thanks.
Old May 18, 2012 | 12:38 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 5.3 wire harness swap ?
This is not an easy swap if you're new to electronics and wiring, so you really want to do a LOT of reading before you grab your soldering iron for the first time.
It is not a throw in and go kinda job, but Pocket's done some great threads in this section. Here's your first step:
https://www.thirdgen.org/forums/ltx-...p-3rd-gen.html
https://www.thirdgen.org/forums/ltx-...rt-finish.html
Old May 19, 2012 | 12:57 PM
krzyz's Avatar
Car: 1982 z28
Engine: 383
Transmission: 4l60e
Axle/Gears: 3.73 posi
yea the truck harness needs some work before you can throw Into ur car, Im using a truck harness for my swap and I had spent at least 4-5 hrs pulling apart my wiring and labling all my wires and Im just starting to lay out my harness again on my engine to finish what is need, the links 1Adan have spoted are the ones I have used to do my harness.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Reddeath210
Oct 6, 2015 08:20 AM
Macchinist
Oct 2, 2015 02:55 PM
jharrison5
Aug 19, 2015 05:53 PM
