Hawks Headers Wideband Bung Location
Old May 21, 2012 | 01:18 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Anyone have a pic of where they welded the bung onto the headers and didn't have clearance issues? 6 speed btw
Thanks!
Old May 21, 2012 | 02:40 PM
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
Re: Hawks Headers Wideband Bung Location
The AFR install instructions do indicate the sensor has to be within the collector section of the header, but I have talked to a number of people and from their and my actual experience have not seen issues with it located farther down the exhaust.
I have installed mine after the collector flange both with my previous 406 SBC and now with the LS1, both without issue. With the LS1 the front bungs that were are already used up with the H2O sensors for the PCM which is much more important than the AFR sensor for gauge indication. If you are tying the gauge into a data logger, you will need to re-evaluate locations.
406 SBC location was here
LS1 Location with T56 trans
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
