5.3 piston help!
Old Sep 10, 2012 | 05:35 PM
sweet_87_iroc's Avatar
Car: 1987 Iroc-z camaro
Engine: 5.7 Liter
5.3 piston help!
I bought a 5.3 lm7 and I need to change out the pistons. Can I change to lm4 pistons? What change will they have for compression? Just looking for a little info from someone who knows better then me.
Old Sep 19, 2012 | 04:43 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 5.3 piston help!
Any 4.8/5.3L pistons will fit
LM4 was a different class of the same bore block family
Old Sep 19, 2012 | 04:53 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Why do you need to change pistons? That said go 10 over to clean up the bores and run flat tops for compression, unless you plan to turbocharge then you want dishes. And to be clear new pistons not used. Never use used pistons in any motor they didn't come out of.
Old Sep 19, 2012 | 07:04 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I will say that used pistons from a engine into another that was bored over is ok, 5.3 bored to LS1 with used pistons or 6.0 bored to ls3/l92 with used 6.2 pistons is ok. Never had a problem with that on a budget.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
