Should I be able to flash SES codes with 94/95 harness and ECM?
Old Oct 15, 2012 | 07:12 PM
cmexlr8's Avatar
Car: 1965 Chevelle SS
Engine: 355
Transmission: TH350
I have what I think is a 95 ECM and harness, but I am not 100% sure - the person I bought it from said it was a 95.
I think I have the ALDL wired correctly:
  • ALDL pin M goes to the tan wire on pin 30 on the blue ecm connector
  • ALDL pin B goes to the white w/ black wire on pin 20 of the blue ecm connector
The SES light is on when the car is on. I tried grounding the wire that goes to aldl pin b and then turning the key to the on position. The ses light does not come on(actually it flashes on very briefly) and the fans come on. I have read some info (shbox.com) that says I cannot flash codes for 94 - up ecms. Is that what the problem is?
Will a scanner be the only way to pull codes?
Old Oct 15, 2012 | 07:37 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: Should I be able to flash SES codes with 94/95 harness and ECM?
Yep scan tool only, and only certain ones will actually do it.
Old Oct 15, 2012 | 07:52 PM
cmexlr8's Avatar
Engine: 355
Transmission: TH350
what year of car would be the year to use for the scan? A 93 or 94? My car is a 92 with the 12 pin aldl
Old Oct 15, 2012 | 10:31 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
94 or 95, it doesnt matter too much for the scan
Old Oct 16, 2012 | 07:31 AM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Yes, but for 95 they switched to a 16 pin ALDL connector so they could use the newer scanner (OBD2), but it was still OBD1. You may need to switch to a 16 pin ALDL to use a handheld scanner since you think the computer is a 95. If it is a 94 you should be able to get away using the stock 12 pin ALDL.
Old Oct 16, 2012 | 12:54 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
If he wants to use most handhelds it would need the 16 pin.
Toolsin
Feb 2, 2016 06:55 AM
jer4251
Sep 1, 2015 09:04 AM
CORV3TT3
Aug 23, 2015 11:26 AM
355tpipickup
Aug 19, 2015 10:02 PM
jharrison5
Aug 19, 2015 05:53 PM
