tunercat won't communicate
Old Oct 27, 2012 | 01:12 PM
diablizzard's Avatar
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
This is an 94 LT1 swap into an 86 camaro. Harness was made by Pocket. Just making sure I didn't miss anything.
I traced the continuity from the PCM to the ALDL, which is good. The ground is also good. I tried to jump A and B to see if it gave the finish code 12, did't get that either. Battery voltage is at 12V.
Edit: I just read that the 94-95 doesn't do flash codes
Old Oct 27, 2012 | 05:36 PM
Car: 86 Camaro Z28
Re: tunercat won't communicate
I think I found it. I'm missing one of the power when key on pins. Now I just need to get a hold of one.
Linson
Oct 24, 2025 02:00 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
ULTM8Z
Oct 2, 2015 01:25 PM
Linson
Oct 1, 2015 09:50 PM
Luigytico09
Oct 1, 2015 08:46 AM
