LS swap converter lock up/disengage
Old Nov 16, 2012 | 08:31 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
So, what are folks doing to cut 12 volts on the ECM for the converter to unlock?
Just a newer brake switch?
Old Nov 16, 2012 | 10:15 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: LS swap converter lock up/disengage
The TCC wire made for this at the C100 connection.
Old Nov 16, 2012 | 11:07 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
This is entirely stand alone, I'll have to see where that is on the car, but the factory brakes supply 12 when presses and I need constant 12 and cut when brakes are hit as you know.
Old Nov 17, 2012 | 12:30 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
As I said, TCC, terminal E7 of the C100.
Old Nov 17, 2012 | 02:58 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
On the camaro harness somewhere?
Old Nov 17, 2012 | 04:57 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
use the cruise control switch on the brake pedal
Old Nov 17, 2012 | 03:43 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Ok, I did not even think to check that.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Cameeeero
Sep 18, 2015 04:00 PM
Jake_92RS
Aug 17, 2015 09:42 AM
gwade12
Aug 8, 2015 08:17 AM
