LSx swap no start 89Formula/98 ECU
Well after all my hard work shes still being a pain in the ***.
my fuel pump is working, I have power at sensors, coils and fuel rails... I have compression.. 160PSI but it wouldn't start, So i pulled a spark plug out and it was dry.. Went ahead and put some starter fluid into the throttle body and it pops now so I can only assume its getting spark and its not the compression igniting it.
This car was previously LSx swapped and I still have the ECU it used, I only assumed vats was tuned out but maybe I am wrong?
Does grounding R 11 Theft Deterrent Fuel Enable (Factory Only) bypass vats?
I built this harness from two V6 harness, So I have some worry it could have been me, But Since its got power and notthing has blown up yet.. I think I did ok.
Transmission: 4L80E/4L80E
Crank sensor failure will cause no-start.
Have you verified what fuel pressure you have at the rail? The fuel pump can sound like it's running without actually pressurizing the fuel at the rail.
Only thing I've heard about VATS is programming it out.
If the car ran before, it shouldn't be a VATS issue.
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: LSx swap no start 89Formula/98 ECU
Could be the PCM, but their failure rate is pretty low. But it does happen.
Do the injectors have the same amount of voltage?
The pule signal is sent through the ground, so check your continuity.
Ill check my grounds again, It will sputter on starter fluid... So I feel like the computer is atlest sending signal too the coils right?
But I guess I could have one ground not working that it needs for the fuel injectors?
Car: Camaro
Engine: 6.2L
Its VATS me thinks. VATS cuts fuel so you need to tune it out of the PCM ( best option ) or you can wire in a VATS bypass module that you either make, or buy. Heck i think I still have one kicking around somewhere
Anyways search it out, you'll find it
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
I know in my lt1 the injector pulse is tied into the ignition/opti. but i dont think thats the case in LS series motors, so might be VATS.
If you dont want to bust out the coin for a tune, you can get a VATS bypass module off ebay for 20$ or so. Pretty simple install
no grounds go to the injectors each injector wire has 2 wires a ignition on and a second wire that goes to the ecm. are you sure your using the correct 97 wiring schematic and not a 99+
So i put a test light on the injectors, The hot with key on is working fine, But the signal wire on the other hand... When I put the test light on the signal wire of the injector, the injector fires and the light comes on and stays on...
I checked my grounds, they are working.. there are 3 PCM grounds correct?
What else could it be?! This is something simple..
red 33 should be inj 1
red 23 should be inj 2
red 9 should be inj 3
red 15 should be inj 5
red 6 should be inj 6
red 27 should be inj 7
red 31 should be inj 8
blue 20 should have power with key off
blue 19 should have power with ignition
Double check those thats everything you need to run
eightsixseven
Dec 16, 2024 01:50 PM
