quick question. des the b body lt1 share the same short block as f body lt1
Is the b body and fbody lt1 short blocks the same? I know the heads are different but I'm not sure of the short block. I can get a 95 Buick lt1 for really cheap. Need help ASAP. I can't find info any where? Also, if I put the alum heads will it pretty much have the same specs as the fbody motor in terms of.compression ratio? Thanks guys
Transmission: 4L80E/4L80E
Same short block (except cam) to the best of my knowledge.
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
Re: quick question. des the b body lt1 share the same short block as f body lt1
All B bodies were cast iron headed due to HD use or weight of the vehicle. only F bodies and vettes had Alu heads (thus higher comp ratio). The short block is the same other than cam as stated above. If you were close I'd sell you the one I have CHEAP! Also there were some revisions on the dist. between 94-96 (Vented VS Non-vented)
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
The B- Body can also have a smaller cubic inch version that looks identical to the 5.7 , so make sure what you're getting.
