started my swap
Old Jan 19, 2013 | 09:07 PM
rsp13's Avatar
Car: 88 Trans am
Engine: 305tpi soon to be ls1
Transmission: t5 soon to be t56
Axle/Gears: 3.08
started my swap
Today I pulled the ls1 and t56 from my donor car today. I've done a lot of research about the swap but for those that have done it if you have any tips or tricks please share them.
Attached Thumbnails started my swap-2013-01-19_11-25   started my swap-2013-01-19_15-12   started my swap-2013-01-19_16-21
Old Jan 20, 2013 | 07:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
First question is whether you've read the LS1 swap sticky in the top section of this forum.
Old Jan 20, 2013 | 08:00 PM
rsp13's Avatar
Car: 88 Trans am
Axle/Gears: 3.08
Re: started my swap
Sure did
Old Jan 21, 2013 | 09:51 AM
coptzer's Avatar
Car: 1986 IROC-Z
Engine: LS1-ish
Transmission: T56 stage II
Axle/Gears: S60 4:10's
Re: started my swap
Whats the story with that donor car? It looks to be in pretty good shape.
Good luck with it!
Old Jan 21, 2013 | 04:27 PM
rsp13's Avatar
Car: 88 Trans am
Axle/Gears: 3.08
Re: started my swap
Looks can be deceiving the interior of the car is trashed and it has a selvage title. I thought about fixing it up be I think third gens are just plain cooler cars.
Old Jan 21, 2013 | 04:41 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
Re: started my swap
Agreed! Good luck with the swap!
Old Jan 22, 2013 | 01:07 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: started my swap
only tip is take your time,the swap isnt bad to do and you have full donor car.are you swapping everything,dash,tank,rearend etc?
Old Jan 22, 2013 | 06:33 AM
rsp13's Avatar
Car: 88 Trans am
Axle/Gears: 3.08
Re: started my swap
I do have the whole car but I plan on building a rear end and keep the stock dash.
theshackle
Mar 5, 2017 06:37 PM
jharrison5
Aug 19, 2015 05:53 PM
cstrobel65
Aug 15, 2015 10:19 AM
mizz0313
Aug 12, 2015 06:45 AM
86Base
Aug 8, 2015 01:34 PM
