HELP WITH LS1 SWAP
Old Jan 23, 2013 | 04:05 PM
CSIMS87T's Avatar
HELP WITH LS1 SWAP
I have a ? about putting a ls1 in my 91 camaro, i have a pa racing k member that had just reg small block mounts on it. where or who sells a kit that has both motor mounts and mounts that bolt on to my k member. whould like for it to be poly on block. and i think i would like to move the engine up an 1inch. so please if any info thanks
Old Jan 23, 2013 | 04:26 PM
Re: HELP WITH LS1 SWAP
Trick question?
If I were in your shoes, my first phone call would be to PA Racing.
Old Jan 23, 2013 | 06:32 PM
CSIMS87T's Avatar
well I tried to but didn't get nobody so I thought I give forum a try. But I belive it would be just like I had a factory k member.
Old Jan 23, 2013 | 08:53 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Pretty much.
Old Jan 26, 2013 | 12:59 PM
Pocket's Avatar
Car: 91 Trans Am
The most common engine position uses 1" back from the common SBC adapter plates like these
If you're moving it up 1", then use the generic adapter plate that classic muscle cars use like these
So get generic SBC mounts for a 3rd gen and use the standard adapter plates
1984HO
Mar 19, 2021 11:59 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
