lsx supercharger setup?
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: lsx supercharger setup?
any of them but mainly wondering about hte magnacharger one since ive seen them on another forum go for $2000 and its very tempting if they are direct bolt on
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Magnacharger doesn't offer a 4th gen f-body kit. I used a GTO kit for mine. Used GTO kits generally sell for $3500-4500 depending on the options and blower size. The kit I used with some upgrades retails for $6K.
I think you can use the Procharger 4th gen kit with some modifications on these cars if you want to go that route..prochargers are generally a bit cheaper.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
http://ls1tech.com/forums/parts-clas...nacharger.html
this is what im thinking of buying. I love the whine of root superchargers i have a svt lightning and the whine sound is so awsome i want it on my ls too.
Car: 1985 IROC-Z
I don't know where you would be able to find the base manifold for that blower...I imagine it's going to be very expensive. I would venture to say you would have another $1K just to get that kit up and running. I'd low ball him if you really want it. Get a hold Magnacharger and inquire about a price for the base.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Oh ok. Do you have a thread on all the modifications you had to do to install your supercharger?
Car: 68,87,99 maros, 07 tbss
Engine: TPI,LS2,LSA,L92
Transmission: T56,T56,T56, 4L80E
Axle/Gears: 12bolts and 14 bolt lol
Yes..the whine is intoxicating! LOL I toyed with putting rear cogs on mine...but I thought that might be a bit much.
Some of my current projects.
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Im gonna make a setup to run a fotd gt500 mp112 on my rs.
I goy the 09 gt500 blower with elbow and snout and stock pulley for 500$ shipped.
600 miles. Looks new.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I'm in the same boat as you, can't decide whether to go S/C or Turbo on my next build. Check out the Huron turbo kits. They are selling for about $3k complete (few thousands less than a S/C) and should fit a 3rd gen with some mods.
http://ls1tech.com/forums/forced-ind...oil-lines.html
If I can find a low mile aluminum 5.3, my H/C LS1 + SSW headers are coming out this summer and TPITERR is going to have a fun project
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
That kit looks really nice! The car i bought had a turbo kit but the turbo i bought did not line up to the down pipe. Sorry its a blurry pic was taking with my POS phone
this is how it was before i was thinking of buying the same turbo he had but it was a ebay one and ive heard too many bad stuff about buying cheap turbos.
Car: 1985 IROC-Z
What are your power goals/ intended use with the car? That will determine your path. S/C's are nice, but they do have limitations...
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Dam this thread is making me wanna turbo my car again. Id like to do it but with the amount of modification needed to put one in I just dont want to as the car sat for 5years already and I dont want it sitting again before I get to drive it. Too bad they dont have a kit for our cars but I guess the demand would be so low for it.
Car: 02 SS
Any interest in a bolt on ford gt500 blower based setup.
Im working on one. at the moment. But it will require a taller hood.
Actually im designing it for ls trucks. But will fit most swaps.
(not 4th gens) but should work on 3rd gens with taller hoods.
Its gonna be at least 3in taller than usual roots blower setups.
And will need a ls truck crank pulley offset.
If anything i can sell just the adapter kit. And belt drive.
But its looking to be bout 4500-4800$ for new everything. Throttle body included.
Ive seen the new gt500s run 9s on full bolt ons,pully,tune on stock blower.
I think they are at the 650rwhp range now
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
my power goals is too have a low 10sec track/street car. Well if i went supercharger i was also thinking of running a 100shot that way would help me reach my goals.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Car: 02 SS
Im goin off a 2011 unit.
Workin on the plenum. Im a machinist, so i can cad and make all the parts.
Im gonna make all the prototype parts manually on lathe, or saw-saw.
It looks like it wil be about 2in overall taller than a gm 2000+ vortec truck intake manifold.
It should fit ls trucks. But the real goal is make for my 91 rs.
I havr a 3.5 cowl hood. So should have no prob. Under hood.
But it will be 100% bolt on and im gonna make so can use common idler pullies and belts from auto zone.
Also im goin to have the factory pancake ac compressor on the rs.
Im gonna keep ac on my car. All with the sc.
All the accesory drive i will make custom out of 6061 .500 plate
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
hmm this is very interesting if you could keep a/c this sounds very interesting something id be into within how long you think you will have the protype?
Car: 02 SS
Its in a build phase.
I machined and worked on some of the parts today during my break.
Still not complete. Im gonna start my build thread with pics,info,etc.
Car: 1985 IROC-Z
Car: 02 SS
Does ur magnacharger have an ic?
I believe i have seen mags, whipples and kb that are non ic.
I have had great results before with pre compressor meth/h20 injection.
It will not have an ic on the first one im building. On mine.
I am looking into adapting a ic though.
I can do it, but im working with as many off the shelf parts as possible.
Have considered 03-04 cobra ic.
Car: 02 SS
I have built a turbo car with pre compressor meth/h20. Its add, kicks out 650rw thru built th400/8.8. motor is just a stock cam longblock 5.3 with dial springs,ported/spring oil pump. Hardened pushrods. Stock ls1 c5 intake and stock truck tb.
Car rolls the f out on plain ole pump gas, never any issues. No fmic.
Just proper maint like anything else. Regular upkeep is all.
Car: 1985 IROC-Z
I know Magnacharger made a kit for the vettes that was non-intercooled..I think they were pretty limited in boost to about 6psi.
The 112's are neat little blowers but they do make alot of heat. I would not run one without an IC. Some guy did over on Tech and roached his motor in short order...probably due to a less than optimal tune which is key to making them last.
Car: 02 SS
im gonna have to take ur word on it about the heat. Im gonna give a try. I dont think the air can really be too much hotter than a mid size tc78 at bout 15psi. Non intercooled. Jusy pte compressor meth/water inj. On psi switch. Spot on tune. Capable fuel system of course.
The turbo comp has to deal with the turbines radiating heat and the mp112 doesnt.
So well see, i believe it will make a full time proper temp 600-650rw on pump and no intercooler on a stock 4.8 with pre comp meth/water injection.
Buily th400/12bolt. Im shooting for high to mid 10s with it
How much does your car make on pump and what does it run?
Car: 1985 IROC-Z
I have never seen a 112 make anything over about 550rwhp. The High helix version however seems to do a touch better.
Here's a little reading for you...also if you go over on to ls1gto.com and search there is alot of good info in the 112's.
http://ls1tech.com/forums/forced-ind...ut-blower.html
I could be wrong but the above blowers do not look like they have an ic. It just looks way too lo pro to have one in there like oe ford blower cars.
Best of luck to you
BTW its a M122 not a M112, those were on the old cobras with a pass inlet
Car: 02 SS
I follwed your thread. Im mounting it on the manifold. Yours was mounted on the side.
Im gonna keep the oe truck crank pulley and run off that.
There is no price set. Hell i could just have a kit to adapt it.
If a car guy can find hid own blower and such. Can do it on the way cheaper side.
Been seeing these blowers at very attractive prices.
The 10 rib drive will be the big spender. Belt spacing is of no importance
You can run them on a 6 rib belt if you like, but the belt wont last very long
An inexpensive manifold would be attractive, but currently no one offers one. Magnacharger used to be a source, but recently will not sell parts individually
Car: 02 SS
Yes gonna run off 6 rib. The mags run off a 6rib jackshaft. I know the jackshaft drives the 10rib in the rear. Im gonna make the brackets to run idler pullies. Gonna use both spring.loaded tensioner. And i alredy make a mechanical tensioner for ls motors.
I expect belt life to be shorter than common use.
I have seen the lowest priced maggies at around 5k$ and that wad the truck kit.
The vette and camaro are significantly higher. Around 7k$
Those are the msrp though. Maybe tje dealers sell lower.
I like the idea that you used for you crank. I have access to machine shop. I can make those parts. But i want to see how much i can get away with 6rib
The gear head in me just wont let it go.
Car: 1985 IROC-Z
I have run the 6 rib for 2 years with no slip on a 3.0 front pulley.
Car: 1985 IROC-Z
1:1 on the rears. I did that to allow a larger front pulley.
Drive ratio is crank diameter/SC pulley
With an over/under driven jackshaft its (Crank/JS front)*(SC pulley/JS rear)
Using those numbers your DR is 2.41 and crank pulley 7.25"
You're right at the verge of what the 6 rib can do if not a little beyond. For reference, my DR was 3.0, so a 6 rib would last about 50 miles before it was ribbons
Car: 02 SS
Currently i have a 7.5 crank and 3 sc=2.5 dr
It may be pushing it on 6rib. I plan on at least 6500rpm shifts.
May have to just build 8rib right off. I really want push this thing. 8rib should help alot.
Car: 1985 IROC-Z
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
well i know i made this thread about supercharger but since its in forced inductions i decided to show you guys what i got
i picked this up today for under $400
Master Power gt45
Master Power gt45
Car: 1985 IROC-Z
It's all good, you'll make more power with a turbo anyways. Both systems have their advantages and disadvantages.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Yeah just gonna have a lil boostlag but i dont think it will affect me too much.
Car: 1985 IROC-Z
I'm actually considering selling my set-up and doing a turbo 5.3.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Car: 02 SS
And im goin from turbo ls to pd ls.
I build hot/cold parts for locals for ls cars. On my own car i just want that roots blower look.
If i really wanted to make big hp. Id build my rs with my twin tc78 on a forged 6.0
My uncle is a dealer for turbonetics. So i get the parts at lower costs. Thats y i use tnetics on everything
