Fuel Line Connections
Old Mar 19, 2013 | 10:15 PM
Randy_M's Avatar
Car: '92 RS Camaro
Engine: '92 SD 305 TPI
Transmission: BW 5 speed
Axle/Gears: Stock Open 3.08:1
I can't seem to do a good enough search to find the information I need.
I am trying to connect stock LS1 quick connect female fuel lines back to the stock third gen hard fuel lines running from the fuel tank to the engine compartment. I need a third gen female fuel line connection back to AN-6. Female AN-6 is preferred but I would appreciate help with either male or female AN-6.
I anyone has any other suggestions on how to do this, I will be more than glad to hear those also.
Old Mar 19, 2013 | 10:43 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel Line Connections
http://www.summitracing.com/parts/rus-640830
http://www.summitracing.com/parts/rus-640820
Is this what you were looking for ?
Old Mar 19, 2013 | 11:55 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Russell also makes fittings that are GM quick disconnect to male AN. I used them to go from teflon SS braid to stock fuel rail.
Randy_M's Avatar
Car: '92 RS Camaro
I believe you have given me just what I was looking for. Thanks a million.
theshackle
Mar 5, 2017 06:37 PM
mdtoren
Aug 23, 2015 12:52 PM
AkDrifted
Aug 17, 2015 07:45 PM
mdtoren
Aug 16, 2015 05:45 PM
86Base
Aug 13, 2015 05:06 PM
