Trying to get this speedo done
Old Mar 31, 2013 | 07:22 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
I have a wierd setup.
my real question is.
Does the ls1 t56 vss output the same way the lt1 t56 does?
I have a lt1 but am using a ls1 t56 so the vss might be different.
my pig tail to hook the vss up should be here any day so I can get that soldered on and be ready to test it.
How its hooked up now.
vss feeds to lt1 pcm via purple and yellow wires.
LT1 pcm speedo output feeds to a gray wire that goes to the dash.
I just wanted to verify if this is correct.
Old Mar 31, 2013 | 07:26 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
Re: Trying to get this speedo done
Sounds like you have it hooked up correctly, far as I know the VSS output is the same between lt1 and ls1 6speeds
Old Apr 6, 2013 | 05:17 PM
Pocket's Avatar
Car: 91 Trans Am
It is the same 17ppr to the PCM which converts it to 4,000ppm the speedo can understand
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
Nervous2
Oct 8, 2015 10:53 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
