lt1 t56 start up, and notta
Old Apr 1, 2013 | 09:40 PM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
So tonight i got everything together tonight on my motor and not even a dome light came on. Pocket made the harness so im sure thats good. Could it be a burnt relay that controls everything. This isnt my first swap,im stumpted
Old Apr 2, 2013 | 07:20 AM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: lt1 t56 start up, and notta
Did you connect a 12G wire from your dist. block to your pos. terminal on the battery?
Old Apr 2, 2013 | 08:19 AM
jaysfs's Avatar
Transmission: t56
I have new battery cables conected. im going home at lunch to clean the ground.by.the battery abd on the block.i painted under the hood so im goin to grind.that spot to bare metal. hows your swap bout.all done? been trolling you pages!
Old Apr 2, 2013 | 08:20 AM
jaysfs's Avatar
Transmission: t56
And yea that wire is.connected
Old Apr 2, 2013 | 09:11 AM
jaysfs's Avatar
Transmission: t56
Old Apr 2, 2013 | 11:59 AM
jaysfs's Avatar
Transmission: t56
Ok there is a red wire that comes off the.harness by the power.box.next.to the.battery.thats where i have my cable hooked up to from the positive battery lost.when i hooked up the jumper cable to the post on the box the car lit up! tye battery was to dead to turn the car over so its charging till i get home. Im thinking i need to run a wire to a post on the box.and the i could hear the starter ingage. also i had a few adult sodas last night .
Old Apr 3, 2013 | 07:28 AM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Good to hear you found the problem. Same exact thing happened to me.
midge54
Dec 27, 2019 04:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sreZ28
Aug 14, 2015 07:48 PM
hokis
Aug 9, 2015 03:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
