Fuel tank/pump
Old Apr 6, 2013 | 05:53 PM
combatdoc's Avatar
Car: 91 z28, 92 ZR1
Engine: LS1, LT5
Transmission: T56, ZF
Axle/Gears: 3.73/ 4.10
Fuel tank/pump
Hey all, I just finished my ls1 swap in my 91 Z28, last night trying to tune the car it died, no fuel pressure, I am running walbro pump and a C5 regulator, I took the cap off and holy cow there was a **it ton of pressure in the tank, not sure why any thoughts? I havent removed the charcol canister yet and the line from the tank is still hooked up, anyway wtf I need some been there done that info, any will help. Thanks Dan
Old Apr 7, 2013 | 10:28 AM
combatdoc's Avatar
Car: 91 z28, 92 ZR1
Engine: LS1, LT5
Re: Fuel tank/pump
ttt
Old Apr 7, 2013 | 10:58 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
Re: Fuel tank/pump
Is it possible it was vacuum and not pressure in the tank? Either way, it sounds like the tank isn't venting, and it should be.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
