LS1 in a 3rd gen...what fuel pump?
Old Apr 12, 2013 | 05:02 PM
92RS4US's Avatar
Car: 92 25th anniversary edition
Transmission: 700R-4
Axle/Gears: 2.73's
is there a in-tank fuel pump that will work with a stock 3rd gen tank and float asm?? if so which one? already searched and found nothing other than use a 4th gen gas tank.
Old Apr 15, 2013 | 08:59 PM
Cash_Mayday's Avatar
Re: LS1 in a 3rd gen...what fuel pump?
I'm swapping a 5.3 into an 89, and I installed an AC Delco EP381 pump into the thirdgen sending unit last weekend. It's from the 96-98 vortec trucks, fits good and makes 60 psi in those trucks. I brazed Dorman 800-154 and 800-155 fitings onto the supply and return of the sending unit, and ran nylon lines and quick connects to a Corvette filter with built in regulator in the stock filter location. Looks good and should work well.
Old Apr 15, 2013 | 09:11 PM
irocdls1's Avatar
Car: 88 Iroc ls1 swap
Engine: ls1
Transmission: 4l60e
Axle/Gears: original disc
Get a racetronix fuel pump works great...255 lph about $100
Old Apr 16, 2013 | 01:19 AM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
you can use a 3rd gen Walbro 255 lph fuel pump, this is what I am running.
http://www.summitracing.com/parts/vp...t/model/camaro
Old Apr 16, 2013 | 07:25 AM
Those are good choices to. I chose the ep381 because it's an AC Delco OEM reliable part, also plug and play fit, rated @ 50/60 gph (227 lph), and can be had for 50 bucks online. If your north of 400hp, or ever plan to be, you probably need one of the other pumps listed although I understand that they can be louder.
Old Apr 18, 2013 | 04:42 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
+1 on this. Dont let people tell you the walbro is loud because i cant not hear mine with the car running. I have very quiet exhaust also.
Old Apr 18, 2013 | 10:01 PM
Pocket's Avatar
Car: 91 Trans Am
Really? The research I did suggested they were walbro190's which is plenty for most swaps
Old Apr 21, 2013 | 12:55 PM
That the ep381 is a walbro 190? Mine came in a delco box and has a/c stamped on it. Its the factory replacement pump for the early Vortec trucks which require around 60 psi at the fuel rail, including 454's and it was also used in Syclones and Typhoons. Most info I've read say's it's rated at 50/60 gph and will support up to 450hp, of course thats all internet hearsay. I hope I'm not spreading misinformation, but I believe it to be true.
Old Apr 21, 2013 | 04:08 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Delco doesn't actually make any parts- they buy them from other suppliers in Delco boxes... Walbro and Bosch probably make most of their electric fuel pumps..
Old Apr 21, 2013 | 05:41 PM
92RS4US's Avatar
Axle/Gears: 2.73's
Yea I found out we use the Walbro 255 pumps at my work. The boss was not at the shop on the day I posted but now I know.
Old Jun 6, 2013 | 06:18 AM
kevinc's Avatar
Car: 1982 Z28
I've been running a Walbro GSS340 high pressure pump from Racetronix, came in a kit that included everything needed to install it on a factory 3rd gen in-tank assembly. It's a gerotor type pump, not plastic turbine, and it's held up to a lot of abuse, starvation, and hard miles. Very quiet also.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
