Aftermarket kmember and issues
Hey guys. Going to go with an aftermarket k member with my second lsx swap. Im going to use fbody acc. I really like UMI but they are out of the picture because the stock AC location will not work and no, I do not want to relocate it.
So, that leaves BMR, Spohn and I believe PA Racing? Besides having the stock Ac fit, will there be any header issues I should be aware of? Im going to run the Hawks 1 7/8 long tubes.
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Re: Aftermarket kmember and issues
I am running a BMR k-member and have working AC on my car, but I am running Hawks 1 3/4" longtubes. I do not think that a little bit bigger primary will affect anything though. One side note is that with the BMR k-member you have to run their A-arms which add to the cost.
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I have a Spohn K-member, engine didn't sit level. Had to do some fab work to one of the motor mounts to fix the issue. Build quality was good otherwise but fitment seems to be hit and miss with the Spohn K-member.
Car: 86 IROC-Z
Engine: 370 LQ9
Transmission: T56 Magnum
Running a Spohn in the Iroc, next time the motor is out Im switching to a BMR or UMI piece. Spohn's are not the way to go, just my
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
This topic has been beat to death many of times.
I'm not trying to be rude but i know there are a few very detailed threads I have seen that cover this topic. Just FYI, save you a little time waiting for responses.
Good luck,
Good luck,
Street Lethal
Apr 30, 2019 12:14 PM
