Y-pipe with Spohn crossmember
Old May 10, 2013 | 04:39 PM
Boreen's Avatar
I am doing an LS3/T56 swap. Everything is coming along nicely. I just bought some Hawks 1-3/4 headers with 3" slip fit connectors. Also bought the hawks y-pipe and slp loud mouth 1 exhaust for an ls1 4th gen.
Headers bolted up perfect with no fitment issues at all. Y-pipe on the other hand, I am not sure how I can even make that fit with the Spohn crossmember.
Is it even possible or do I need the hawks crossmember?
I've also read that the hawks double hump crossmember doesn't fit as well as the Spohn unit.
What should I do?
Should I just get a y-pipe built using parts from the hawks y-pipe?
Even with the hawks crossmember, will the y-pipe fit or would it still gimme issues?
Car is gonna be lowered slightly on modded sportlines, and eventually (hopefully next winter) it will get air ride.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kammi10
Nov 9, 2015 08:28 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Zell1luk
Sep 29, 2015 10:36 AM
