LT1 swap parts list question
Old May 28, 2013 | 08:47 PM
Dvolion11's Avatar
Car: 88 Camaro IROC, 92 Camaro RS.
Engine: 305 tbi, LT1
Transmission: 700r4, 4l60e
Axle/Gears: 3.43
Okay so my 1st question is im looking at getting a new radiator with duel fans,will this rad work with the lt1?
http://www.ebay.com/itm/3-ROW-ALUMINUM-RACING-RADIATOR-2X-12-FAN-82-92-CHEVY-CAMARO-FIREBIRD-TRANS-AM-V8-/190769733273?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1988%7CModel%3ACamaro&hash=item2c6ac31e99&vxp=mtr
2nd question I was searching about the swap and i came across that if I install a/c I can use a '95 caprice right side motor mount? will I still have to notch the k-member using this mount?
3rd question does anyone know where I can get a 4thgen rear end with posi and disk brakes?
And finally what mods should I do while the engines out the car? Lt4 hot cam?
Old May 28, 2013 | 09:47 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: LT1 swap parts list question
That radiator should work, not sure which hoses you will need though.
You use the motor mounts from your third gen, and notch the K-member, or you can get a Corvette Acc. Bracket to avoid any cutting.
Check Craigslist or other forum sites for people parting out 4th gens. They are pretty easy to come by.
Good Luck!
Old Jun 22, 2013 | 05:59 AM
Borden88's Avatar
Car: 88 Trans am t-top
Engine: 5.0L 305 TPI looking for a new one!
Axle/Gears: 3.23 i think
can someone plz help. looking for a 305 tpi or lt1 for my 88 trans am and what exactly do i need to do. will be having a 700 r4 behind.
thanks, brandon
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
