4l60e Cooler line flow direction
Car: 86 IROC-Z
Engine: 370 LQ9
Transmission: T56 Magnum
Just wanting to make sure I have the routing correct.
Trans is a 4l60e, radiator is a stock thirdgen replacement. On the trans the top fitting is the return, connecting to the lower fitting on the radiator. And the bottom fitting on the trans is the feed, connecting to the top fitting on the radiator.
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
Re: 4l60e Cooler line flow direction
Pressure to the top of radiator, return to lower. Thats how mine is hooked up.
Car: 86 Z28/86 IROC
Engine: 305 LG4/ LT1
Transmission: 700R4/4L60E
Ive had the coolers crack inside the rad twice now, immediate death of the trans, i run a air cooler up front.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Dialed_In
Aug 20, 2015 01:45 PM
