LS1 Swap Alternator Relocation Issue's
Old Jun 18, 2013 | 12:32 AM
ecstasyrs's Avatar
Car: 1990 RS and 1991 RS
Engine: LS1 and 350
Transmission: auto and manual
Ok so im doing a ls1 swap in my g/f's 90' RS and the Tubular K-Member is getting in the way of the alternator so i wanted to run the Corvette Alternator / Power Steering bracket from a 1997-2004 on it so it would bring the alternator top side. I already relocated the A/C compressor to the top passenger side as well and was wondering if anyone on here would know beside the bracket what else am i gonna need for the Vette Alternator bracket and where the hell am i gonna be able to find a belt for this, lol.
Old Jun 18, 2013 | 08:33 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
Re: LS1 Swap Alternator Relocation Issue's
Not sure?? But this makes me nervous. Was gonna get a tube k-member in the future but if its gonna hit the Alt. May be not..
Old Jun 18, 2013 | 06:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You need the Vette damper, because the belt isn't as far forward on the Vette system as f-body or truck. Also, the AC compressor relocation bracket will have to be for the Vette application for the same reason.
When you have everything installed, run a string around everything in the route the belt will go. Measure the length of string required to form the complete loop. Subtract a little for the tensioner (forget how much I subtracted, I think 1/2" or 1" - took a couple of tries), take the length # to your parts store, get one that length. If they can't help you without looking up the application, go to a different store.
Old Jun 18, 2013 | 09:35 PM
ecstasyrs's Avatar
Engine: LS1 and 350
with the A/C im running the Holley A/C relocation bracket. All i need now is the Alternator setup. Ty for you response this helps me out alot.
Old Jun 19, 2013 | 04:55 PM
Pocket's Avatar
Car: 91 Trans Am
If its the Spohn K-member, the alt output stud hitting the chassis brace bracket is a common problem. Cut it off and the Fbody alt location will clear
Old Jun 20, 2013 | 01:50 PM
ecstasyrs's Avatar
Engine: LS1 and 350
That is the issue, now when i was reading if i cut that off and don't run the bracket the welds will weaken on the k-member and eventually break?
Old Jun 21, 2013 | 09:30 AM
Pocket's Avatar
Car: 91 Trans Am
That was Spohn's solution to the issue when I first found it. Considering how flimsy the bracket is, I dont see any chance of failure from chassis flex
The weak points are the notches in the main hoop for the tie rods, but thats a different thread
Old Jun 21, 2013 | 10:23 AM
five7kid's Avatar
You didn't say how, but you said you already relocated the AC on the passenger side. The stuff from these guys will allow you to do that with the alternator: http://www.kwikperf.com/lsx_alt_ps.html
You need to keep everything for the same system. The damper, AC, alternator, and PS all need to be truck, or they all need to be f-body, or they all need to be Vette.
Or, cut the brace.
Old Jun 23, 2013 | 11:17 PM
ecstasyrs's Avatar
Engine: LS1 and 350
With the A/C i had ordered the holley relocation bracket for it and for the Alternator i went and found a Corvette alternator / power steering bracket for 70 bucks that i plan on running now.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
reiderz iroc
Aug 13, 2015 04:57 PM
