low mileage LT1 - need a refresher?
Old Jun 18, 2013 | 01:40 PM
Fueled's Avatar
Car: 08 G8 GT, 98 Z28, 86 IROC, 85 Z28
I recently acquired a fairly low mileage LT1 - original owner said 29k miles. It's been sitting for some time so I'm debating on what to do with it. The oil was pretty much black goo and the coolant was equally nasty. Engine came from a wrecked car and ran fine when pulled. It is fairly low mileage as I can still see the cylinder cross hatching with a bore scope. It still had the original plugs also which looked pretty clean. No rust visible in the cylinders either.
My question is this - should I tear the thing down and inspect everything? I was thinking about replacing all gaskets and maybe the optispark before attempting to use it. With only 29k miles should I even bother with the head gaskets? Right now it's completely assembled with all the accessories.
Any thoughts other than get rid of it for an LS...
Old Jun 18, 2013 | 03:10 PM
cumminsN14's Avatar
Car: 86 Z28/86 IROC
Engine: 305 LG4/ LT1
Transmission: 700R4/4L60E
Re: low mileage LT1 - need a refresher?
I picked mine up for what i thought was a score, it was pretty nasty with oil crud on it, they pulled it from a wrecked car and said it was running great also. I cleaned it up, got new gaskets top and bottom, pulled rod cap and a main to check for wear on the bearings and they looked great with 86k miles on this motor. I had the intake off as i was doing a cam swap and noticed a streak of oil from between head and block in the lifter valley. Decided to pull heads and yep, blown head gasket but on the side that looked clean. Its hard to say if you have the engine apart to the point of pulling the heads, might as well do it. I took the opportunity to port my heads once i had them off. I would keep it though, it easier to swap than a LS imo and it can haul some *** too.
Old Jun 18, 2013 | 05:06 PM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
No......
lol j/k, run it
Old Jun 19, 2013 | 10:16 AM
Fueled's Avatar
I was thinking at the very least to replace the rear main seal while its out. I've heard the LTs are prone to leak there.
Old Jun 19, 2013 | 01:34 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Replace all of the gaskets except the headgaskets, when you have the oil pan off you can better inspect each of the bores from the bottom, so long as they all look good finish with the regasket process and enjoy.
Old Jun 19, 2013 | 04:53 PM
Pocket's Avatar
Car: 91 Trans Am
RMS along with oil pump should be a given whenever an engine is out of the car
Run it, I wouldnt replace anything else unless it was suspect. Opti included
Any money spent is money not spent on a real engine in the future
Old Jun 22, 2013 | 04:36 AM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Throw it in asap! The LT1 is a match made in heaven for the thirdgens, This is the engine GM should have put in 91-92s as a 1le to 1up the IROCS but GM Did what the guy with the pink suit had on in mind.
Old Jun 22, 2013 | 04:41 AM
89rs454's Avatar
Car: 1989 SS
Oh yeah and pocket This badass stock LT1 is coming for you!
Old Jun 24, 2013 | 08:42 AM
Fueled's Avatar
Thanks for the feedback guys. I don't mind spending a little money or time up front to ensure the longevity of this motor. I'm not planning to modify it much from stock with the exception of exhaust. I haven't had a fuel injected third gen in a while so I think this LT1 will be fun to drive
db057
Apr 28, 2019 07:45 AM
New2Chevy
Sep 28, 2015 12:35 AM
amcnellis
Sep 16, 2015 04:16 PM
TrevinE
Sep 14, 2015 03:20 PM
L0tuS
Sep 4, 2015 11:16 PM
