tbi on a 5.3 for simplicity?
Old May 29, 2013 | 08:17 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
has anyone ran a tbi on a 4.8/5.3 using a carb intake and a tbi adapter?it seems the simplist way to install a 5.3 into a tbi car.i realize a custom chip would be needed.i already have a tpi ful pump.
Old May 29, 2013 | 08:21 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: tbi on a 5.3 for simplicity?
The expensive part woul be the conversion timing cover to drive the dizzy.
Old May 29, 2013 | 08:30 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
I would think it would be a little more involved than just slapping on an intake and tuning a chip for it. Not to mention TBI can be a pain to tune itself. The easiest way would be to just carb it, you could even use your stock TBI fuel pump.
Old Jun 1, 2013 | 10:42 AM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
either use the stock type FI or carb it, tbi would be hard to tune on that motor, as well as youd need aftermarket covers and cam stuff perhaps a dist as well. i think its doable just alot more involved and more costly than its worth. would it be cool yes but i doubt thered be any gains, it may even limit everything.
Old Jun 1, 2013 | 07:30 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Dont let the wiring scare you!! Literally only a few wires have to be hooked up and it'll run. Most of the work is deleting things you don't need and making it neat. Once its running, figuring out what you don't need is easy.
By the time you adapt the tbi, custom chip, and figure out your igniton, you could have purchased a standalone plug and play harness from a reputable seller and be way ahead of the game!!
J
Old Jun 3, 2013 | 07:55 PM
zenish's Avatar
Engine: 305 tbi
anyone familiar with this company?
http://charlotte.craigslist.org/pts/3831854786.html
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Gordonr1973
Sep 29, 2015 11:59 AM
dusterbd
Sep 29, 2015 08:40 AM
