Had the cylinders "glzae broke" Use stock size rings?
Old Oct 15, 2013 | 03:10 PM
Podium's Avatar
S I had the machine shop "break the glaze" in my cylinder walls on my ls1. My question is do I use stock size rings? Im using stock pistons as this is a freshin up.
Also, what rings do you guys recommend?
Old Oct 15, 2013 | 06:08 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Re: Had the cylinders "glzae broke" Use stock size rings?
If its just a cylinder hone, then you can use stock rings and pistons.
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
