LS1 dash and wiring with swap? or No?
Old Oct 23, 2013 | 10:07 AM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
Sorry for the questions guys but I'm really trying to decide how to tackle this monster of a project. As you may know I recently bought a 98 Z-28 to use as my donor car. Well I've acquired some of the swap parts I need, mainly the mounts, notch plate and a few other things. But I'm considering yanking my stock dash out and installing the 98 dash and wiring... I know someone done this, can't remember who... but thinking about it seems like I could use the LS1 engine harness and body harness... that way I could have automatic headlights and everything.
How big of a PITA is doing this and would it be worth it?
Old Oct 23, 2013 | 12:09 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LS1 dash and wiring with swap? or No?
Shroom did it a long time ago and documented it well
There's a lot of little things that need to be done to make it work and look right
The wiring aspect is the easiest of any conversion. Basically use every wire from the 4th gen. Switch the exterior lights around and you're done
Old Oct 23, 2013 | 01:49 PM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Seems like a straightforward swap. Since I have the whole car I'm going this route, even having to fab a thing or two it seems worthwhile. It'll be nice having the newer interior with auto headlights and everything. Not to mention cup holders with the LS console.
Thinking off the top of my head the only wiring I'll have to mess with will be the body harness correct? Which is mainly the headlights and taillights. Should be easy enough... I'm going to see if I can find the write up shroom did. Hopefully its still on here. Thanks pocket
Jorlain
Aug 24, 2022 05:11 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
reiderz iroc
Aug 13, 2015 04:57 PM
stalkier
Aug 13, 2015 12:59 PM
apie2546
Aug 8, 2015 07:12 AM
