93 lt1 into 87rs
Old Nov 26, 2013 | 09:14 AM
x91z28x's Avatar
Car: 1991 Chevy Camaro Z28
Transmission: Automatic 700
93 lt1 into 87rs
hey been looking around the site and had a few questions. I found a complete lt1 car for 1200 on craigslist, with t-56 and body damage so was gonna pick it up for my swap. question is how much difference is there between to computers on 93-94 and up. I know instead of flashing you would tune with chip. seeing if it will be worth it in the long run
Old Nov 26, 2013 | 10:53 AM
Pocket's Avatar
Car: 91 Trans Am
Re: 93 lt1 into 87rs
93 is a completely different animal, most similar to the SD TPI corvettes
94-95 is the ideal system for swaps. Inexpensive tuning software, common, easy interchange
96-97 is OBDII. Nothing really negative about the system aside from cost of tuning software. A 94-95 PCM can be used on a 96-97 harness without any mods, but no the reverse
You can use ANY system on ANY LT1 by changing a few minor parts
Id buy the 4th gen even if you abort the swap. Parting it out will yield a profit
Old Nov 26, 2013 | 12:06 PM
x91z28x's Avatar
So if I understand you correctly pocket I could buy a 96 97 harness and pcm and few parts and could work with 93 motor? I only saying 93 right now because of the deal, can't beat a drivable lt1 with t56 for 1200
Old Nov 27, 2013 | 05:13 PM
Pocket's Avatar
Car: 91 Trans Am
Yeah, a 96-96 timing cover is required for the OBDII PCM because of the crank sensor
Why not use a 94-95 system and run the 93 engine as-is?
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
